Activity Forums Adobe After Effects I’m stumped
  • I’m stumped
    Posted by Robert Paynter on January 16, 2008 at 4:59 pm
    What I’m trying to do is track two points of a human in motion.
    Lets, say for example, the hand and the foot. Then create a string between to two. Easy enough with corner pin, stroke, etc., Heres the challenge I would like to add arrows on either end that would follow the angle the line is creating.
    got that ?
    anyone have any advice, answers?
    Darby Edelen replied 18 years, 8 months ago 3 Members · 2 Replies
  • Steve Roberts
    January 16, 2008 at 6:36 pm
    This is probably an expression thing – try posting in the Expressions COW.
  • Darby Edelen
    January 16, 2008 at 7:58 pm
    I would recommend applying the position tracking data of one point to Null A and the position tracking data of the other point to Null B. Then try a Generate > Beam effect between the Null A & Null B. You will need to use an expression to link the start and end points to Null A and Null B’s positions, I recommend this one:
    l = thisComp.layer("Null A");
    fromWorld(l.toWorld(l.anchorPoint);
    You will also need to have an expression to rotate the Nulls properly based on their positions, this should work applied to their rotation properties:
    nullA = thisComp.layer("Null A");
    nullB = thisComp.layer("Null B");
    p1 = fromWorld(nullA.toWorld(nullA.anchorPoint));
    p2 = fromWorld(nullB.toWorld(nullB.anchorPoint));
    v = p1 - p2;
    radiansToDegrees(Math.atan2(v[1], v[0]));
    Then create two arrowheads (Arrow A and Arrow B). Parent Arrow A to Null A and Arrow B to Null B, move them into position and rotate them properly relative to the Nulls and you should be good to go.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
