Activity Forums Adobe After Effects I’m stuck on this tutorial pls help
  • I’m stuck on this tutorial pls help
    Posted by Bobby Sifon on December 19, 2021 at 2:45 pm
    Hello Guys, here’s my problem
    I have been trying to follow this tutorial below, but I’m not making his exact logo I’m using mine and I’m not using all his elements. But my issue is at 13:01 when he disables the dot
    at the bottom left [for the logo gloss]. When he does that, his logo shape appears but when I do the same as shown in my video below I get a black screen [can’t see my logo]. Can someone help me out so that I can proceed on with the tutorial thanks?
    Newbie in AE, so a graphic or step by step explanation will be easy for me.
    I’d appreciate the help guys.
    thx
    Here’s the Youtube tutorial link that i am following [my problem is at 13:01]:
    https://www.youtube.com/watch?v=FdUzIrd65Ic&list=LL&index=12&t=676s
    Here is my video at where I’m stuck [my logo just disappears]:
    https://files.fm/f/ftc5turfw
    Here are my files:
    https://files.fm/u/76dej57n8
    Bobby Sifon replied 4 years, 8 months ago 2 Members · 2 Replies
  • Robert Müller
    December 20, 2021 at 9:29 am
    The dot you mention is a switch to solo certain layers, that means all other layers are hiddeb except the ones with the dot. As you see in your video, the null layer at the top also has the dot present, so everything besides your null layer is hidden. Clicking on the dot of your null layer should fix your problem
  • Bobby Sifon
    December 21, 2021 at 2:57 pm
    Thanks Robert for your response
    will check it out….
