Activity › Forums › Apple Final Cut Pro Legacy › I’m shooting a film in 720p. For scanned photos to use in FCP, what DPI must I use?
Posted by Noam Osband on August 23, 2011 at 9:20 amI’m making a film in 30fps, 720p. I’m going to be scanning photos for the project to use in Final Cut Pro 7, the software I use for editing. What resolution should I scan on? I imagine past a certain point, it doesnt make a difference how detailed it is, and I dont want to do more detailed than necessary since it’ll take a long time.
Any thoughts?
Jeremy Garchow replied 15 years ago 2 Members · 8 Replies -
Jeremy Garchow
August 23, 2011 at 11:42 amDpi doesn’t matter with video, pixel size does.
For FCP, nothing over 4000×4000 pixels and 72dpi
Jeremy Garchow
August 23, 2011 at 2:40 pmDpi isn’t going to make a difference in video. Only pixel count.
Keep the scanner at 72DPI and a pixel count of no more than 4000×4000.
If you go over 4000×4000 FCP has a tendency to freak out. So you can scan over that pixel count, you will then adjust size later.
Jeremy Garchow
August 23, 2011 at 3:24 pmHmm. I guess I could see that.
My scanner works in pixels so it doesn’t matter much.
Jeremy Garchow
August 23, 2011 at 8:53 pmI guess I’m not following you. Yes, I scan it big if there are going to be moves on it. If for whatever reason I want to scan at a specific pixel size (therefore limiting what I can do) than I just scan @ 72DPI and the pixel size/crop that I want.
You know I was just reminded of this:
https://library.creativecow.net/biscardi_walter/BCM-FCP-Tip-4/1
Jeremy
Noam Osband
August 25, 2011 at 8:37 amthanks for all the answers. this post has proven quite educational.
So, I’d like to scan at 4000×4000 pixels so I have room to zoom in if wanted.
I have a friend with this printer and I can use it: https://www.find-printers.com/printers/manufacturers/pos/brother_mfc-490cw
Can i do that with this printer? It only lists DPI in its specs, saying that it’s scanning resolution is 1200×2400 dpi and the enhanced resolution is 19200×19200 dpi. Will this do?
Jeremy Garchow
August 25, 2011 at 2:36 pmThat should be plenty. Hopefully the software lets you work in pixels.
Jeremy
Noam Osband
August 28, 2011 at 4:58 pmWhat software lets you work in pixels? I’m using Vuescan and I dont seem to have that option
Jeremy Garchow
August 29, 2011 at 3:28 pm[Noam Osband] “What software lets you work in pixels? “
It’s a networked printer/scanner/copier from HP that has it’s own software.
You first do a preview scan, then setup the final scan with the crop/”aspect ratio” that you want in pixels.
It’s called HP Scan.
Jeremy
