Activity Forums VEGAS Pro I’m prevented from burning Blu-ray
  • I’m prevented from burning Blu-ray
    Posted by Paul Gregory on November 30, 2012 at 1:01 am
    I’m almost ready to burn my first Blu-ray but have run into a couple of problems.
    I’m using DVDA 5.2 & when I do the preliminary check before burning a disk I see the following message several time. ‘The inactive button default colors should be set to none’ I am unaware of any any buttons that are inactive. Should I be concerned about this warning or just ignore it. If not where do I fix it? I suspect that this doesn’t matter much as it appears to be just a warning.
    The second problem is more concerning. It I go to to Optimize disk it tells me that I’m am using 97% of the disks capacity & the only thing thing that doesn’t have a green tick is a small audio file which says needs to be re compressed.
    I then go back to the burn disk option & see the same messages as listed above. I the click to burn & it says that I’m only using 97% of capacity but the finish option is greyed out. The only option left is optimize so I press this & again it tells me 97%. The only button left for me to press is fit to disk & it drops down to 95%. If I then click OK all see is what I had before but this time it’s showing 95% but still no active button to burn.
    Whats going on? Isn’t 97% allowed on Disk? or is there some other problem or setting that I haven’t considered?
    Thanks in advance
    Paul Gregory replied 13 years, 9 months ago 2 Members · 2 Replies
  • Nigel O’neill
    November 30, 2012 at 3:01 am
    Instead of trying to burn, does DVDA allow you to prepare the image file?
  • Paul Gregory
    November 30, 2012 at 3:07 am
    It’s when I click the click Make Blu-ray disk that it take you to the next screen that gives you the options of prepare or burn. Both choices have the options greyed out & I can go no further.
    Thanks in advance
