I’m having trouble setting up and outputting broadcast audio correctly
A job I recently got was supposed to be just as social media output, but then they decided they wanted it for broadcast as well. They sent me the specs for French broadcast: 1920×1080 Prores 422HQ, 25 frames per second, EBU R128 all pretty easy but its this part that I can’t get right. They sent this below:
There is no secondary language so only channel 7 and 8 are useful.So they can deliver ProRes with 8 audio channels (mono). Channel 7 is audio left Total and channel 8 is audio right total.
—-This is what I did, am I correct on this:
1. New sequence multiplex, clicked the + tracks and added all eight. Tracks 1-6 output assignments are off, audio 7 &* output assignments are 7&8 pan left on 7 pan right on 8.
2. I set Modify audio channels on footage to mono 2 audio clips.
3. Turned off mapping on first 6 mapped 7&8 to pan left and pan right.
4. The footage and audio looked like this on the timeline.
5. Exported the file with these settings in media encoder.
6. Once it was done,I opened it in Quicktime and set track 7 to left total and 8 to right total.
Does this look correct considering the Specs? I sent them one version that they didn’t except, they said this “The Prores version received had an issue because all 8 audio channels was multiplexed into one audio track instead of 8.” I don’t have any experience delivering Broadcast and its really confusing. I would be grateful for any help. Thank you.
~David
