Activity › Forums › Apple Motion › I’m having a issue with motion
  • I’m having a issue with motion
    Posted by E. lee White on July 15, 2015 at 8:20 pm
    I set some key frames on a image I have moving out from a wall of images. I have the image rotate 360 from the original position come to a point on the stage. Then I hold the image there for a brief moment.
    Then I set another key frame and move the image back across the stage with another key frame. Then the final key frame I type in the exact numbers for the original position the image was in on the wall. Yet when it falls back into place the image is larger than what it was in its original position on the wall?
    I copy all the information for the original image for the last key frame placing the image back in place.
    E. lee White replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
