Activity Forums Apple Final Cut Pro Legacy I’m Crashing . . Will Final Cut 7 help????
  • I’m Crashing . . Will Final Cut 7 help????
    Posted by Rory Keenan on March 28, 2010 at 1:58 am
    I’m Crashing all the time . . . . Will Final Cut 7 help stop crashes????
    I’m running Final Cut Pro 6.0.4 on a
    Mac Pro Quad Core Intel Xenon 3GHz Dual Processors
    12 gig of RAM
    Video Card: NVIDIA GeForce 8800 (512MB of VRAM)
    I’m working on a feature legnth documentary with about 40 bins & maybe 40 hours of footage.
    Right now our main sequence is about 1 hour long.
    Will upgrading to Final Cut 7 help with this problem???
    Is it the nature of this project (length of the sequence, the size of the project)????
    David Roth weiss replied 16 years, 4 months ago 4 Members · 4 Replies
  • Shane Ross
    March 28, 2010 at 2:40 am
    Well, we don’t know WHY you are crashing. Unless you know why, you don’t know if the upgrade will help you. I have worked on projects that are MUCH larger than that.
    What CODEC are you working with? HDV? DVCPRO HD? ProRes? DV?
    Where is the footage stored? What OS are you running? What version of QT? What version of FCP? When it crashes, does FCP produce a crash log? If so, can you post it here?
    Shane
  • Martin Phillips
    March 28, 2010 at 6:42 pm
    Hi Rory – I was in the same boat as you with almost the same setup. I was having regular crashes and slight weirdness with FCP6. So I did a complete reinstall of everything but upgrading to FCP7. It has all been a lot more stable since doing this – I’m not sure whether that has something to do with the clean install. Anyway, I am slightly of the opinion that the combination of FCP6 and Snow Leopard was where the problems lay. Anyway, I am 2 weeks into the new install and it certainly seems better. Hope this helps. Martin
  • Rory Keenan
    March 28, 2010 at 11:55 pm
    We are running Mac OS 10.5.8
    The project is DVC Pro HD 720p 23.98fps
    Could our OS be conflicting with FCP 6 (even though we are not running Snow Lepord)????
    We’d been crashing a lot and were thinking of upgrading to FCP 7.
    However in the last 2 days things have gotten worse.
    We just got a new RAID drive array.
    I copied all the media over on to the new drive . . . . and after I relinked, FCP recognized the media.
    It’s a CalDigit 3TB RAID array . . . . CalDigit makes their own SAS card to go with the drives and we had a local IT guy install the card (he consulted phone support from CalDigit)
  • David Roth weiss
    March 29, 2010 at 1:14 am
    [Rory Keenan] “Could our OS be conflicting with FCP 6 (even though we are not running Snow Lepord)????
    This has nothing to do with the Leopard OS. Version 6 of FCP has been running just fine under Leopard since it first came out, for more two or so years now.
    See my response to the other thread you started on this subject: https://forums.creativecow.net/readpost/8/1080602
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
