Activity › Forums › Apple Final Cut Pro Legacy › Im Confused
Im Confused
Posted by Simon Chan on April 16, 2007 at 5:14 amSo does Pro422 work without special hardrives?
Simon Chan replied 19 years, 5 months ago 4 Members · 7 Replies -
Dan Riley
April 16, 2007 at 5:59 amThe data rates are similar to DVCPRO HD, so 800 firewire RAIDS
are probably fine. But with any video editing, and this isn’t just for FCP,
the faster the hard drive array, the more levels of real time video
you can see without rendering. But once rendered, it looks like from
what I see so far, you could output the new ProRes to tape from either
one or more 800 firewire drives. Tomorrow down on the floor, we will all
learn the real skinny. Regardless for me, I’m going with eSATA RAIDs.
Fast, easy to set up and cheap, relatively.And speaking of drives, if you were to purchase that new iO-HD
and hook it up to the 800 firewire port of a Macbook Pro, I seriously
doubt you could also hook up 800 firewire drives with your video files to the same bus
and it work ok. You will need to get an express card to Firewire or eSATA adapter
and hook up your drives that way.Dan
David Roth weiss
April 16, 2007 at 6:37 am[Simon Chan] “without special hardrives?”
Simon,
You already have SCSI drives. What is your definition of “special hard drives?”
DRW
Walter Biscardi
April 16, 2007 at 7:13 am[David Roth Weiss] ”
You already have SCSI drives. What is your definition of “special hard drives?””Yeah, I was about to ask the same question.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Simon Chan
April 16, 2007 at 4:15 pmYes I have a Blackmagic System. Its about 2 years old. I have Huge System SCSI 1.2 TB Drives. Im just curious because im looking into a new system. Wondered if my drives are obsolete.
Simon Chan @ Artificial Army
G5 Dual 2GHZ 1.5 Gig Ram, Decklink HD, Atto UL4D, Huge 320R, Final Cut HD, After Effects 6 -
Simon Chan
April 16, 2007 at 4:18 pmHow do I change my profile? my system has been updated since I wrote that signature.
David Roth weiss
April 16, 2007 at 6:50 pm[Simon Chan] “Wondered if my drives are obsolete.”
Simon,
In some ways yes and in others no. Apple no longer supports SCSI officially, but as long as your SCSI drives continue to work, they are certainly fast enough for DVCProHD, 8-bit uncompressed SD, and all the lower bitrate formats such as DV and HDV. Apple’s new HD codec that was announded yesterday should do fine on SCSI. If you get into uncompressed HD, that’s another matter entirely, that requires gobs and gobs of hard drives.
DRW
Simon Chan
April 16, 2007 at 9:58 pmI actually edit HD 720 and 1080 Uncompressed 10bit fine on my HMV U320RX and Decklink HD card. My question is can anyone now with the new Apple ProRes 10bit edit on standard drives that come with the Mac Pro?
