Activity Forums VEGAS Pro I’m a noob. Effects trouble
  • I’m a noob. Effects trouble
    Posted by David Bennett on June 9, 2012 at 12:50 pm
    Just got Vegas. I figured it out pretty well, but I can’t figure out how to apply Video FX (like, spherize for example) for set times during the video, so it only happens when I want it to happen. (so it gives it like a bouncing in and out look, in this case).
    I”m sure it’s not very hard, so please help.:)
    Jeff Schroeder replied 14 years, 2 months ago 3 Members · 2 Replies
  • Roger Bansemer
    June 9, 2012 at 2:17 pm
    Well, if I’m understanding it correctly…
    what you want to do is adjust the time an FX lasts on the event. (event meaning one clip of a video on the timeline)
    At the bottom of the Video Event FX you’ll see a button that says “animate”. Click it and a window will open.
    Scrub down your timeline where you want the effect to change and then slide the effects at the top to make the change.
    A diamond will appear where the change will take place.
    You can slide these diamonds around where every you want them once you’ve placed them.
    You can also click the “+” sign button on the animation window to insert another point for adjustments.
    Roger Bansemer
  • Jeff Schroeder
    June 9, 2012 at 2:20 pm
    What you want to do is keyframe the effect. Most effects have a ‘reset to none’, that would be your first keyframe then a few frames later set your next one for the desired effect and then later, another one set back to none. Read up on keyframes in the help file.
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
