Activity Forums Maxon Cinema 4D I’m a lost newbie…..
  • I’m a lost newbie…..
    Posted by Amish Ed on March 1, 2006 at 12:31 am
    I have a Couple newbie questions for y’all. I’ve only been using C4D 9.5 for a couple weeks now, so these might be stupid questions. My previous 3D experience has only been ‘postcards in space’ in After Effects and the Innivigorator pluggin. I tried the C4D manual, but for being 1000+ pages it leaves much to be desired.
    1) Is there a way to take a selection from one object and use it on another object? In my case I’m building a tooth: I have the roots and I need to use the top of them (where they meet the enamel) to cut off the bottom of the enamel.
    2) Is there a way to subdivide an objects mesh w/in a selected area? Or, do I have to do the whole object? I tried making a selection and then using the subdivide function. But, all it did was divide the whole mesh. I know I can go in and use the knife, but it would take forever. Makes me think I must be missing something.
    Thanks for any input.
    Amish Ed
    “Shoot ’em all and let the Editor sort ’em out!”
    Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
    Amish Ed replied 20 years, 6 months ago 2 Members · 4 Replies
  • Designbytes
    March 1, 2006 at 1:27 pm
    for #2: the object you are using needs to be “editable” – ie. not a primitive, etc but polygon object; then you need to be in “polygon” tool mode (as opposed to points, edge tools) and select the polygons you want to subdivide. they will turn color when selected; then find “subdivide” under the function menu
    for #1: not sure if the “tooth” is two separate objects or one; I suspect maybe one and that the roots and top are the same object; if so, get in polygon tool mode again and select the root area; then find “set selection” under the selection menu; this will save that selection set under the object and that “set” can be activated at anytime for use in texturing, further modeling, etc
    recommendation: can the manual for now – and refer back to it as you learn more; check out tutorials here and particularly http://www.c4dcafe.com and other forums; they are invaluable in getting a handle on C4D and to “think” C4D
  • Amish Ed
    March 1, 2006 at 3:46 pm
    Thanks for responding. As for #1 I was in points mode, so that explains where I went wrong there. Seems obvious now. For #2 the tooth is 2 objects; roots and crown. But, I’ll try setting the selection and see what happens. Thanks for the help.
    Amish Ed
  • Designbytes
    March 3, 2006 at 11:02 am
    …back to your “top of roots” problem….early morning learning going on here, so mileage may vary:
    ** select top of root object as required (poly mode);
    ** pick function–> split (this duplicates and separates the selected group into a new object);
    ** position the top-root object a close to where you want it in relation to the enamel object;
    ** select enamel object and newly created top-root object and pick function–>connect (this creates duplicated, but connected object)
    ** join the mesh of the two objects using create poly or bridge tool
    presto! …I think 😉
  • Amish Ed
    March 3, 2006 at 3:41 pm
    Thanks, I’ll give that a try.
    Amish Ed
