Activity Forums Avid Media Composer iLok for ProTools 10
  • iLok for ProTools 10
    Posted by Jessica Mantheiy on October 3, 2012 at 4:07 pm
    I already know the answer to this question, but I want to make sure I found the correct answer.
    Can you run ProTools 10 without iLok? If so, if you have a valid activation code, how can I use it without the dongle?
    Jessica Muth
    jmuth01@gmail.com
    Mark Spano replied 13 years, 11 months ago 2 Members · 1 Reply
  • Mark Spano
    October 5, 2012 at 6:08 pm
    I am sure you cannot use any current flavor of Pro Tools without an iLok with its authorization. If you have an activation code, then you should be able to get an iLok, create an iLok.com account, and use the activation code on Avid’s site to deposit the authorization directly into your iLok account. Then you go to iLok.com, log in, and with your physical iLok connected, you can transfer the authorization to the dongle.
