Activity Forums Adobe Illustrator Illustrator Won’t Launch
  • Illustrator Won’t Launch
    Posted by Orrin Zucker on July 3, 2010 at 8:43 pm
    Hi-
    So I need some help here…Illustrator CS4 won’t launch, I get no error message, just a bouncing icon and…nothing.
    I’ve tried trashing all the illustrator files in preferences (settings and plist), repairing disk permissions with Disk Utility and even reinstalling Illustrator. No luck.
    No other programs is effected…
    Any ideas?
    David Cabestany replied 16 years ago 3 Members · 3 Replies
  • Vincent Rosati
    July 3, 2010 at 11:15 pm
    Add all of your system spec’s to your profile so we can see what you’re working with.
    Have you rebooted?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Orrin Zucker
    July 4, 2010 at 12:11 am
    Yup- rebooted first thing.
    It’s a mac laptop pro 10.6.3 2.26 GHz Core 2 Duo w/ 4 GB of Memory 1067 MHz
  • David Cabestany
    August 17, 2010 at 11:01 pm
    Try the following:
    restart holding command S
    wait until the black screen appears
    after it stops writing stuff you will see a line that reads root# or something like it (can’t remember exactly and would have to reboot to see it)
    type fsck -f (the space must be included)
    the computer will run a series of tests/operations
    it will fix whatever needs to be fixed.
    when it’s done it will read the volume [name of your hard drive] appears to be ok.
    depending on whether it changed something or not the lien ***FILE SYSTEM WAS MODIFIED*** will be there or not.
    type reboot
    try to start illustrator after that.
