Activity Forums Adobe Illustrator Illustrator: turn off video safety template guides
  • Illustrator: turn off video safety template guides
    Posted by John Bradley on November 27, 2008 at 7:15 pm
    I feel very sheepish asking this question but it is driving me crazy.
    I used one of the video templates in Illustrator CS3 to work on designing an opening sequence for After Effects.
    I like to be able to at various points view my comps without the safety lines but I can’t find where to shut them off!
    In Illustrator,
    how can I toggle on and off those bright green video safety lines??
    I am normally a photoshop guy, but I am trying to become comfortable in Illustrator and not go running back to PS every time I hit a roadblock.
    I know it must be the simplest thing in the world that I am overlooking… but I cant find what it is that shuts them off?
    It must be possible… right??
    Christian Belanger replied 7 years, 1 month ago 7 Members · 8 Replies
  • 8 Replies
  • Ronaldo Montalvo
    November 29, 2008 at 7:42 pm
    i think the implementation is a bit funky but vid safe lines are a kind of crop in illustrator. when you select the crop tool the options will show up on the top menu bar and the ability to turn various components of the tv safe display on/off. you can also double klik the crop tool to see various display options for which lines of the tv safe display. selecting crop “make or release” allows you to delete them.
  • Jesse Perry
    December 2, 2010 at 10:36 pm
    In CS4, click the “Artboard Options” button under the menus at the top of the screen. Then de-select Show Center Mark, Show Video Safe Areas, and Show Cross Hairs.
  • Randy Cates
    February 14, 2013 at 3:37 pm
    In CS5 go to Window/Artboards. In the Artboard menu that opens, in the upper right corner, select Artboard Options from the sub menu.
    In the dialog that opens un check:
    Show Center Mark
    Show Cross Hairs
    Show Video Safe Areas (or any one depending on your needs)
    This drove me nuts for a while as well. To get them back reverse the above.
    R.Cates
  • Paul Roper
    June 17, 2013 at 11:05 am
    THANK YOU! I went through every menu imaginable to get rid of these bloody guides. What a palaver.
    – Paul
  • Paul Roper
    April 6, 2018 at 3:52 pm
    Ha! And co-incidentally I’ve found myself back here, once again fighting with the god-awful abomination that is Illustrator, trying to perform something as simple as turning off those stupid guides!
    motion graphics | VFX | web design | etc.
    https://paulroper.com/
  • Christian Belanger
    June 26, 2019 at 2:06 pm
    Works perfectly!
    However, is there a way to also turn off the rulers?
  • Kalleheikki Kannisto
    June 28, 2019 at 6:26 am
    View>Rulers>Hide Video Rulers
    Senior Graphic Designer
    June 28, 2019 at 2:23 pm
    Thanks! 😀
