Activity Forums Apple Motion Illustrator to Motion 5 script
  • Illustrator to Motion 5 script
    Posted by Marc Segarra on July 9, 2012 at 5:33 pm
    I was trying to open .Ai files in Motion 5.0.4, but it’s impossible for me to load it with unfixed resolution, it loads the vectors as images.
    I was looking for a Fixed resolution checkbox in Media, but it doesn’t appear for me.
    Otherwise, I read that exists a script to convert AI files from Illustrator to Motion, but the site is down because MobileMe it’s no longer avialable.
    https://www.motionsmarts.com/downloads.html
    The file was called: il2motionshape.zip
    And the script: Export as Motion shape.js
    Someone can post the file or the zip? It will be helpful for the rest.
    Thank you very much in advance.
    Stephen Smith replied 14 years, 1 month ago 2 Members · 4 Replies
  • Stephen Smith
    July 9, 2012 at 7:25 pm
    To change the “Fixed Aspect Ratio” do the following: Open up the Project Pane. Click on the Media tab. Select the AI file. Click on the Inspector tab in the Inspector. Select the Media tab if it is not already selected. Un check the Fixed Resolution check box. Jaggy edges become smooth.
    Be sure your Illustrator file is RGB.
    By the way, you can not work with the individual layers in a multi layered AI file in Motion. You can do it in AE. To work with multi layers you need to convert the AI to a PSD. Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Marc Segarra
    July 9, 2012 at 7:42 pm
    Stepeh,
    Thank you very much for your answer.
    Are you using Motion 4?
    Because in my version, 5.0.4 it doesn’t appear me the checkbox for disabling fixed resolution 🙁
    You can see it here: https://img441.imageshack.us/img441/61/fixedresolution.png
    I’m going crazy with this!
    Thank you very much again!
    Hope someone can help.
  • Marc Segarra
    July 9, 2012 at 7:47 pm
    I’ve just found it.
    Excuse me for all!
    Thank you very much!!!!!!!!
  • Stephen Smith
    July 9, 2012 at 7:49 pm
    Happy to help and best of luck.
    Stephen Smith
