Activity Forums Apple Final Cut Pro Legacy Illustrator to DVD losing res somewhere
  • Illustrator to DVD losing res somewhere
    Posted by Eric Klassen on December 29, 2006 at 11:40 pm
    I have some text created in illustrator saved as a .ai (I’ve tried both jpeg and psd exports as well), imported into FCP, rendered using compressor dvd settings. I’m getting garble on the text. Is there some chain of exporting that I need to be aware of? Something else?
    Eric
    Eric Klassen replied 19 years, 4 months ago 3 Members · 4 Replies
  • 13 Create COW Profile Image
    13
    December 30, 2006 at 3:54 am
    you NEVER said what type of video you are trying to add it to, with out your DETAILS there is not much help that can be given
  • David Roth weiss
    December 30, 2006 at 7:26 am
    [zrb123] “you NEVER said what type of video you are trying to add it to”
    I’ll bet ya 10 to 1 he’s adding it to a DV timeline.
    Eric, if I’m right right about that then I’ve just identified where that big hit on your text is coming from. The only way to preserve the quality is to uprez the project to DV50 or 8-bit uncompressed.
    DRW
  • Eric Klassen
    December 31, 2006 at 9:41 pm
    David,
    You’re right, I’m adding it to a DV timeline. I’ll try those settings.
    Eric
  • Eric Klassen
    January 1, 2007 at 10:43 pm
    David,
    I’ve noticed when ever I create text and/or graphic clips using LiveType, I don’t get this problem. Is that because LiveType is working in the 8 bit or DV50 compressions?
    Eric
