Activity Forums Maxon Cinema 4D Illustrator to C4D
  • Illustrator to C4D
    Posted by Ben Peterson on August 4, 2015 at 12:04 am
    Im trying to export a logo with text from illustrator to c4d. I save as ill 8 then open in c4d and my logo is there but firstly it is surrounded but a very large spline which I need to delete then another one colorer to the logo which I also delete. Second the layers that overlap in illustrator are opening in C4D as one object. For e.g. I have a filled hexagon on top of a filled star then on top of that some text. The hexagon ends up being a hole through the star. This is not what I want.
    I have tried searching for tuts on this and all I can find are lame youtube ones that dont explain anything except how to save in illy then open in C4D. I need some more details about ow to save and open the way I want it. I have tried putting on separate layers in illy but this made no difference.
    Ben Peterson replied 11 years, 1 month ago 3 Members · 3 Replies
  • Brian Jones
    August 4, 2015 at 5:16 am
    there is a setting in Illustrator to export (or not) the limits of the document (don’t remember what it’s called, don’t have Illustrator here…)
    if you have multiple spline segments in a single spline you can select the spline and run the Mesh/Spline/Explode Segments command
  • Tony Barone
    August 5, 2015 at 3:30 pm
    I believe you have to save the Illustrator Document as an Illustrator 8 eps file. Haven’t done it in a long time since finding this very useful plugin call CV-Artsmart. It lets you copy/paste from Illustrator to C4D!
    https://www.cineversity.com/vidplaylist/cv-artsmart
  • Ben Peterson
    August 7, 2015 at 10:22 am
    There is no setting inside illustrator to not export limits of document I have looked everywhere and not found it. Mesh Spline explode segments is greyed out.
