Activity Forums Adobe Illustrator illustrator to c4d problem
  • illustrator to c4d problem
    Posted by Stavros Theiakos on July 10, 2011 at 4:14 pm
    Hello.
    I hope this is the correct place to post this as I am new here.
    Ok I have a closed spline created with the pen tool in illustrator. it is basically something like a water drop that consists of two points with broken handles in order to get the shape as I liked.
    I know I have to save as illustrator 8 in order to import in C4D.
    Problem is that when I merge it in C4D it comes up half. (Like a half “O” would be with symmetry on the y axis but in the shape of a water drop)
    I know I could do the shape inside C4D to solve this but thing is I had to use illustrator in order to outline from a picture.
    Any help will be good . Thanks
    Les Nemeth replied 15 years, 2 months ago 2 Members · 1 Reply
  • Les Nemeth
    July 11, 2011 at 4:51 am
    It’s not an AI problem. It’s a C4D “problem”. You have to close the spline from within C4D.
