Activity Forums Adobe Illustrator Illustrator to After Effects Q
  • Illustrator to After Effects Q
    Posted by Adam Lewen on June 30, 2016 at 6:33 am
    Hi there
    I am working in AE for a long time, and when facing the issue i’m about to address, I had my tedious way of getting it “the way I want” for AE.
    I am getting designed text. A lot of text. Each letter (!) is made out of 3-4 layers.
    I want these layers to be arranged in LAYERS for AE to give me each 3-4 layers of each letter.
    I am attaching an example of ONE letter
    Is there a simple way of getting 3 layers from this example?
    the tedious one, for me is, in this case; duplicating X 3 and deleting 2 paths from each duplicate… X a lot of letters…
    I hope I am clear!
    (also I hope I am very inexperienced with illu, and there is a magic button…)
    Any input is appreciated!
    Adam Lewen replied 10 years, 2 months ago 3 Members · 4 Replies
  • Kalleheikki Kannisto
    June 30, 2016 at 7:22 am
    You have a clipping group (in AI) which is pretty much analogous to a precomp with a mask (in AE).
    Do all the letters have the same type of color fill with the same three triangular color areas in the same colors? If that is the case, you could bring in just the clipping path as a path (copy/paste) as a mask for a precomp that contains those base colors, duplicating the precomp as many times as you have letters and pasting the letter outlines as a mask to each.
    Of course, the workability of this depends on what you’re planning on doing with the letters once you have them in AE.
  • Adam Lewen
    June 30, 2016 at 7:24 am
    Thanks fro replying.
    Let me test and see if I understand what you mean…
    Ill update 🙂
  • Jason Jantzen
    June 30, 2016 at 6:25 pm
    An even easier solution would be to “release” the clipping path for each letter, delete the clip shapes, ungroup everything, then on the layer stack in AI, select the top layer (NOT the circle) and then select the context menu and then “release to layers”. I made a tut on that here https://vimeo.com/50564308
    Then import that AI file as a composition in AE and select “Layer Size” for footage dimensions. It would be wise to name your layers in AI or AE at some point.
    Select all the layers that are the color shapes for each letter and click the “Preserve Underlying Transparency” button for all of them (it’s under the switches and modes column). If you need more help from there, let me know.
    Jason Jantzen
    vimeo.com/jasonj
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Adam Lewen
    July 3, 2016 at 9:28 am
    Thank you so much for the detailed reply!
    Great great help from both of you!
