Activity Forums Adobe After Effects Illustrator Strokes get converted to Filled shapes in AE?
  • Illustrator Strokes get converted to Filled shapes in AE?
    Posted by Jeremiah Belt on September 30, 2016 at 7:13 pm
    I have an illustrator graphic made up of all strokes. When imported into AE and converted to shape layers, all the strokes turn into filled shapes matching the thickness of the AI graphic’s strokes. I want them to stay as strokes so I can utilize Trim paths. What am I missing here?
    Jordan Lindley replied 7 years, 9 months ago 3 Members · 5 Replies
  • Jeremiah Belt
    September 30, 2016 at 7:31 pm
    I want to be able to animate each individual stroke drawing on. If I bring it in as an illustrator file I would have to animate all that by hand with masks following the strokes or using the draw on tool. All of which would take forever. Having the strokes as individual strokes in AE allows you to use the trim paths feature to automatically draw on the strokes. I do it all the time but for some reason this illustrator file’s paths get converted to filled shapes in AE.
  • Jeremiah Belt
    September 30, 2016 at 7:35 pm
    Discovered the issue!! The path style has to be basic otherwise AE converts it’s thickness to a shape.
  • Roei Tzoref
    September 30, 2016 at 7:44 pm
    Yep. if you have anything but constant width and basic brush, it’s going to be convert to fill.
    this doesn’t mean you need to compromise your creative vision. you can still draw a path in the middle of your illustrator fill and use this as a base for a reveal either by stroke effect or even trim path via Alpha Matte.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Jeremiah Belt
    September 30, 2016 at 7:45 pm
    good call
  • Jordan Lindley
    November 27, 2018 at 4:17 pm
    Jeremiah, I’ve run into the same issue. Where do you change the path style to basic? I can’t find what you’re referring to.
