Activity Forums Adobe After Effects Illustrator storyboard to After Effects motion
  • Illustrator storyboard to After Effects motion
    Posted by Naomi Reed on September 6, 2021 at 11:50 am
    Hi all
    This feels like it should be an easy thing but my brain just can’t get there.
    I’ve created a storyboard in Illustrator of a character swinging. In each stage of the movement I have changed the shape of the head, as if it is turning with the swing. I’m trying to figure out a good way of making these angles of the head seamless when importing in to After Effects and animating the swing.
    At first I thought using the Path to morph the shape would be a good way but the Illustrator shapes have a lot of detail and texture “drawn inside” them, so with that there is a load more path options which aren’t greatly manageable.
    Does anyone have any suggestions for this? Thank you
    Graham Quince replied 5 years ago 3 Members · 2 Replies
  • Eric Santiago
    September 7, 2021 at 12:10 am
    Aside from going frame by frame, Illustrator vectors can be quite cumbersome with any morph option.
  • Graham Quince
    September 8, 2021 at 8:47 am
    This is Eran Stern’s explanation of how to morph – as Eric said, it’s quite cumbersome but should be possible.
    https://www.youtube.com/watch?v=q3A-JtGB27U
