Activity Forums Zaxwerks Illustrator sequence
  • Illustrator sequence
    Posted by Vince Becquiot on January 16, 2006 at 9:37 pm
    Is there a way to use an illustrator image sequence inside invig ?
    I have a countdown leader/Logo animation I would love to transfer to 3d.
    Vince
    Vince Becquiot replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    January 17, 2006 at 2:47 am
    Hi Vince,
    Absolutely! We call it layer cycling and it’s one of Invigorator’s really powerful features. I use it to accomplish morphs, deformations and complex motions that couldn’t be done any other way. And yes, I’ve used it to create a 3d coundown as well. (the numbers morph from one to the next).
    When you build your Illustrator file, think of it as cell animation… a sequence of images on a sequence of layers. When you import the file into your Invigorator project, use the “import as layer cycling object” option. You’ll be able to control many aspects of playback once you’ve done that.
    If you get stuck, post a question and we’l lhelp you through it.
    Have fun.
    Jon
  • Vince Becquiot
    January 17, 2006 at 5:58 am
    Thanks Jon,
    Just realized you had just the right tutorial posted as well.
    Just didn’t see the feature in the manual.
    Thanks a lot !
    Vince
