Activity › Forums › Adobe Illustrator › illustrator problem ” Acrobat PDF Fils Format is having difficulties. The File is damaged and could not be repaired.”
  • illustrator problem ” Acrobat PDF Fils Format is having difficulties. The File is damaged and could not be repaired.”
    Posted by Cody Lee on May 7, 2015 at 7:04 pm
    when i open the ai file, i get this error message.
    do you know what to do?
    Lyons Ethan replied 11 years, 4 months ago 3 Members · 2 Replies
  • Vincent Rosati
    May 8, 2015 at 12:17 am
    I suspect the file is just plain corrupted 🙁
    Try opening with Acrobat, and experiment.
    Try running it through Distiller.
    Try opening with Photoshop.
    Here’s Adobe’s troubleshooting info for this issue: https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-files.html
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Lyons Ethan
    May 11, 2015 at 7:14 pm
    Is it possible that the PDF file format is to new for your version of illustrator to import? Which version of illustrator is it?
    For more use Illustrator Repair Toolbox restores corrupted *.AI files in vector graphics editor Adobe Illustrator. Software read corrupted file, analyze data in it and save a recovered data into new .ai file. https://www.repairtoolbox.com/illustratorrepair
