Illustrator PDFs Breakup on playback
Hi All. This is my first post.
I’ve created a simple 16 second clip using 5 vector PDF logo’s.The 3D camera essentially rotates 90 degrees each time as each logo scrolls onto the stage. When playing back in Motion everything works as it’s supposed to. However after rendering to a .H264 movie, three of the logos play back perfectly and two breakup. Very frustrating. All PDF’s are Illustrator CS5 in RGB. MacBook Pro, i7, 8Gb RAM. Here’s a link to the YouTube:https://youtu.be/nsIOzEGj2q4
Cheers,
RichardSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
