Activity Forums Adobe After Effects Illustrator pattern tile problem in After Effects
  • Illustrator pattern tile problem in After Effects
    Posted by Jeff Coleman on August 11, 2015 at 2:37 pm
    Created an illustration using patterns in Illustrator (18.1.1). Looks great in Illustrator even when scaled up tremendously.
    When imported into After Effects (CC 2014) and especially when scaled up a bit I see what look like thin strokes/lines on every tile of the pattern.
    How can I get rid of those lines?
    Project folder here:
    9133_micpatternproblemfolder.zip
    (Saw similar post 2 years ago, but it’s solution of turning off continuously rasterize didn’t work in this case)
    jeff
    Jeff Coleman replied 11 years ago 53,544 Members · 2 Replies
  • Jeff Coleman
    August 12, 2015 at 3:48 pm
    don’t see that in comp settings.
  • Jeff Coleman
    August 20, 2015 at 1:45 pm
    Several associates have reproduced this tile pattern anomaly on various Mac systems. So I don’t think it’s some sort of configuration, setting, plug-in, or operator error. BTW: CC 2015 produced the same results.
    I don’t know if it’s a tile pattern error in Illustrator or an error in AE’s continuously rasterize function.
    As a workaround, in Illustrator I replaced the patterns in the file with my own shapes (think lots of shapes).
    Two plus hours with Adobe tech support last week elevated the case to Tier 2 (48 hour call back) support. That was 6 days ago and haven’t heard anything yet from them.
