Activity Forums Adobe Illustrator Illustrator pattern problem.
  • Illustrator pattern problem.
    Posted by Charles on May 4, 2005 at 12:21 pm
    Date: May 3, 2005 at 22:18 gmt
    Subject: Illustrator pattern problem.
    I have a problem with Illustrator.
    I have a element that I want to fill with a pattern that I made myself (made it from my background image).
    (see: https://www.trancevibez.com/koozftp/Charles/Screen1.jpg )
    But when I define it to my element and I move the element the patters stays at the same position so that it changes every time I move it. Is there a way to define it to my element so that it stays the samen wehen I move it?
    (see: https://www.trancevibez.com/koozftp/Charles/Screen2.jpg )
    I tried it also with another pattern (standaard from Illustrator) but the it does the same.
    I can not work with transparancy because of all the layers behind that need to cover each other.
    I hope I explained it clear enought. Any suggestions?
    Thnank you for your time.
    Grtz. Charles
    Charles replied 21 years, 4 months ago 2 Members · 2 Replies
  • Kim Mackenzie
    May 4, 2005 at 6:38 pm
    Transform Palette > flyout menu > change it from Transform Object only to Transform Both. Should do the trick.
  • Charles
    May 5, 2005 at 9:47 am
    Yah!!! thank you so much!
    Gr. Charles
