Activity Forums Maxon Cinema 4D Illustrator paths not extruding
  • Illustrator paths not extruding
    Posted by Les Lanphere on June 14, 2008 at 1:14 am
    I’m trying to extrude a logo. I brought it into C4d and i can see it fine, but the extrude nurbs isn’t doing anything once the paths are inside it.
    I made a spline, to see if it was something crazy and the spline extrudes, no problem. Is there some conversion I have to do before an illustrator path will work in an extrude object?
    Brian Jones replied 18 years, 3 months ago 3 Members · 3 Replies
  • Nolan Scott
    June 14, 2008 at 3:13 am
    Using Cinema 4D 10.5 / Illustrator CS / OSX 10.4.11
    Well, works fine here…
    Please make sure that the spline is closed…
    I presume you have exported as “Illustrator Legacy (ai)” with the Options “Illustrator 8”…
    Cheers
    Nolan
  • Les Lanphere
    June 14, 2008 at 3:22 am
    Thanks for looking at this. I found the issue. When i brought in the paths they were placed in a null object. Apparently you can’t place a group of paths into an extrude. Once I connected the paths into one path, all was well.
    Thanks again,
    Les
  • Brian Jones
    June 14, 2008 at 3:31 am
    you can place a bunch of splines in a null, you have to check off Hierarchical in the ExtrudeNurb object
