Activity Forums Adobe Illustrator Illustrator path
  • Vincent Rosati
    March 31, 2007 at 8:24 am
    Ideally (here), you’d want 2 blue objects and four red objects, created by the Divide operation.
    It looks like you’ll need to chop off the the three pointed corners with the Knife Tool, if Divide didn’t perform the cut.
    Once your corners are removed and you have the final form, you’ll select all of the components and press Alt+Pathfinder/Add to Shape Area – or, Add to Shape Area than Expand.
    This will make a unified shape.
  • Julian Sixx
    April 1, 2007 at 4:36 am
    Hi
    thank you Vincent.The Knife tool did the trick
