Activity › Forums › Adobe Illustrator › Illustrator newbie question (artboard)
  • Illustrator newbie question (artboard)
    Posted by Ponyack on September 10, 2005 at 5:09 pm
    hi
    I have artwork that is outside the artboard, how can i move the artboard so that the artwork is inside the artboard or vice versa..
    thanks
    ponyack
    Richard Harrington replied 21 years ago 2 Members · 1 Reply
  • Richard Harrington
    September 10, 2005 at 6:08 pm
    Change your document size under the File menu or drag the artwork in using the selection tool
    HOWEVER…
    I answered becuase you asked nicely…
    Look on the home page
    Media Professionals User Forums – More Signal, Less Noise….
    This is not a place for questions that would be solved from readingthe first chapter of the classroom in the book or user manual… if you are going to purchase expensive software, be sure to investigate basic funtionalty through training.
    Good Luck
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
