Activity Forums Adobe After Effects Illustrator needed for job
  • Illustrator needed for job
    Posted by Olly Lawer on March 15, 2012 at 1:14 pm
    Hi
    You’ll probably tell me i’m posting this in the wrong forum, but I need two things.
    1. To know what to tell our existing illustrator of how to design for after effects, so I can edit the various different elements (say a person)
    2. A really good illustrator that can produce illustrations like in this example:
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    What is KashFlow from KashFlow on Vimeo.
    Olly Lawer
    Olly Lawer replied 14 years, 5 months ago 4 Members · 5 Replies
  • John Cuevas
    March 15, 2012 at 1:57 pm
    If I were asking for objects like the smiling head at 10 seconds my biggest criteria would be that the designer give me layered files with each layer clearly labeled. Hat, Head, Eyes… Then save it as an RGB .ai file. Gives me the ability to import as a comp and have each layer be seperated, and this way you can take advantage of the ability to use continous rasterization on the vector images(no scaling issues)
    Too many times I get files that will by CMYK with 100’s of elements thrown into one layer, which I have to manually seperate to work with them in AE.
    So that’s my .02 cents.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Todd Kopriva
    March 15, 2012 at 2:21 pm
    There are some more tips in addition to the good ones given by John here:
    “Preparing and importing Illustrator files”
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Cassius Marques
    March 15, 2012 at 5:17 pm
    I would like to add that if I leave the “use compression” checked (during illustrator save). my illustrations won’t appear half the time…
    neither reloading nor replacing them seem to help, they will sometimes randomly disappear during render or project reopening. (it doesn’t happen with all the files…but it happens a lot, big headache until I discovered the cause)
    This information doesn’t show at the page Todd linked. Have you heard of this before Todd?
    CS5 here.
  • Todd Kopriva
    March 15, 2012 at 5:19 pm
    I’ll look into that. I hadn’t heard of that issue before. Thanks for bringing it to my attention.
  • Olly Lawer
    March 16, 2012 at 6:21 pm
    Thank you so much for your replies!
    Hunted down local animator, so going to get him to design the illustrator files for AE.
    Thank you tho! This knowledge will really help with future animations when we are not up against it so much!
    Olly Lawer
