Activity Forums Adobe After Effects illustrator masks to AE masks
  • illustrator masks to AE masks
    Posted by Lori Newman on August 13, 2008 at 3:05 pm
    Thanks in advance for any help. I’m creating a word in Illustrator, copying the mask and pasting in After Effects on a solid. I have to do a morph from a drop of water into the word. Is there a way to set up the file in Illustrator so when I copy the mask it can come into AE as just one mask, instead of several (masks that drop out holes in letters) because I can’t figure out how to morph with all of those separate masks in AE.
    thanks!!
    Bobby Shepherd replied 18 years, 1 month ago 2 Members · 1 Reply
  • Bobby Shepherd
    August 13, 2008 at 9:56 pm
    Unfortunately not.
    It’s more of a physical impossibility than a deficiency in either program. One mask for the outer, one for the inner.
    You can probably get a good start by using the AI paths, but this situation will require a LOT of manual tweaking.
    Good luck,
    -B
