Activity Forums Adobe After Effects Illustrator Layers are only 3 frames long when imported
  • Illustrator Layers are only 3 frames long when imported
    Posted by Mitchell Powers on April 12, 2017 at 8:20 pm
    Importing a layered Illustrator file.
    Checking Import as Composition and Layer Size.
    Imported comp is only 3 frames (and change long)
    Here’s what I’ve tried:
    Created a new comp that’s one minute long. Then reimported Illustrator files. Same result.
    Changed import preferences to specific length. Same result.
    Changed preferences back to comp length. Also same result.
    There’s no checkbox for image sequences, I’m in creative cloud. Any ideas out there?
    Tim Kurkoski replied 9 years, 4 months ago 2 Members · 3 Replies
  • Tim Kurkoski
    April 12, 2017 at 8:46 pm
    I’m guessing you are using macOS.
    There is in fact a sequence checkbox in the Import dialog, but macOS likes to hide it. Click the Options button in the lower-left corner of the Import dialog, then disable “Illustrator Sequence”.
  • Mitchell Powers
    April 12, 2017 at 8:57 pm
    Yes, I see it now!
    Tim, I could smooch ya.
  • Tim Kurkoski
    April 12, 2017 at 9:32 pm
    You’re welcome.
    If you’re coming to NAB, stop by the Adobe booth and we can work out an appropriate gesture of your affection.
