Activity Forums Adobe After Effects illustrator into zaxwerks
  • illustrator into zaxwerks
    Posted by Zac on October 25, 2006 at 5:36 pm
    i have a text logo that i want to bring into AE and Invig Pro. I converted text to outlines and when i try to open illustratoe file in invig it says file has no vector paths. What am i doing wrong. I tried saving as a eps file and as a illustrator 8 file aswell. I keep getting same error.
    Zac replied 19 years, 10 months ago 3 Members · 3 Replies
  • Serge Hamad
    October 25, 2006 at 5:50 pm
    When you save your file in Illustrator, make sure the use compression box is unchecked. This of course if you are using IL CS.
    BTW. EPS files won’t work with Invigorator only “ai” and saving to version 8 of IL is only required if you are using a very old version of Invigorator.
    Does this help?
    Salut.
    Serge
    “InvigoMany” Available here:https://www.nyc-visual.com
  • Reloaded
    October 26, 2006 at 11:02 am
    He is right. I had this same problem. Just don’t use compression for the Illustrator files.
  • Zac
    October 26, 2006 at 11:29 am
    The compression box did it. thank you fro your response.
