Activity Forums Maxon Cinema 4D illustrator into c4d
  • illustrator into c4d
    Posted by Hamid Rohi-bilverdy on May 31, 2010 at 7:41 pm
    hi.
    Sorry for this basic question. How do i import a illustrator file into cinema4d. ? I use c4d R11.5.. I just created a text in AI and saved it as normal Ai file.
    Tim Shetz replied 16 years, 3 months ago 2 Members · 3 Replies
  • Tim Shetz
    May 31, 2010 at 7:49 pm
    When you save it, you have to select to save it as an Illustrator v8 file. Then you should be able to bring it into C4D with no problems.
  • Hamid Rohi-bilverdy
    June 1, 2010 at 4:46 pm
    is that an option in illustrator cs4 to save it as a v8 file? Or do i name it my self?
  • Tim Shetz
    June 1, 2010 at 7:42 pm
    It’s an option in all Illustrator versions to save as previous versions. First you select save, make sure you have Illustrator .ai selected (as opposed to .pdf) when you hit save you will be presented with options…see attached image.
    Tim
    C4DTraining.com
