Activity Forums Adobe Illustrator illustrator into c4d
  • Vincent Rosati
    May 31, 2010 at 8:06 pm
    Save the AI file as version 8.
    There are a number of Illustrator import preferences you should familiarize yourself with in C4D also.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
