Activity Forums Adobe After Effects illustrator into AE comp too short
  • illustrator into AE comp too short
    Posted by Heather Crank on May 28, 2007 at 7:07 pm
    I’ve never had this problem before, and it seems like it should be a simple fix. When I import illustrator files as a cropped layers comp into AE the duration in the timeline is super short. When I try to stretch them or the comp itself, they will only go so far. I need to them to stretch to the end of the entire comp. Any idea why this is happening???
    THANK YOU!!!
    Heather
    Heather Crank replied 19 years, 3 months ago 2 Members · 3 Replies
  • Steve Roberts
    May 28, 2007 at 7:34 pm
    Did you check your import prefs for “still duration”?
  • Heather Crank
    May 28, 2007 at 7:35 pm
    hmm, I’ll check that now.
    Thank you!
    Heather
  • Heather Crank
    May 28, 2007 at 7:40 pm
    yep, it worked!
    Thanks so much!
    H
