Activity Forums Adobe After Effects Illustrator Importing Problem
  • Illustrator Importing Problem
    Posted by Aharon Charnov on January 1, 2007 at 1:36 am
    I am trying to copy a closed illustrator path into AE directly to use it as a mask. But AE is not recognizing clipboard elements from Illustrator.
    This just started happening. Anyone know what might be causing this?
    ACC
    Mylenium replied 19 years, 8 months ago 2 Members · 1 Reply
  • Mylenium
    January 1, 2007 at 10:03 am
    Check your clipboard settings in Illu. The must be set to AICB, not PDF-compliant. Maybe you somehow reset it.
    Mylenium
    [Pour Myl
