Activity › Forums › Adobe Illustrator › Illustrator illustration
Posted by Kim on December 31, 2005 at 10:39 pmHello,
anyone know how this effect is done in Illustrator?
/Kim
Andrei Lutic replied 20 years, 7 months ago 4 Members · 4 Replies -
Richard Harrington
January 2, 2006 at 11:44 pmThat’s raster and probably done in a 3D program
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
Kim
January 2, 2006 at 11:53 pmok, I thought so myself but Istock claimed it was made in Illustrator so I was just curious. Thanks anyway!
Del Holford
January 3, 2006 at 5:54 pmHi Kim
Something similar can easily be done in Photoshop using the stylize>extrude filter, which makes blocks. I did the extrude on a photo, put a distort>twirl on it then another stylize>extrude and got an interesting effect. Not sure what you need but thought I’d throw in the thought.Del
Del – fire*, smoke*, photoshopCS Charlotte Public Television
Andrei Lutic
January 6, 2006 at 8:35 amI think you can make something similar in Illustrator. First you must paint all those rectangles using a scatter brush with the size, spacing and scatter set to random. After that group them and create the 3d effect using envelope distort with mesh or top object. HTH
