Activity Forums Adobe Illustrator Illustrator Help – need to cut a picture
  • Illustrator Help – need to cut a picture
    Posted by Jofo on April 19, 2005 at 3:28 pm
    Hi – newby here…
    I use Illustrator 9.0 to design pictures and adverts for work. I have been asked to create a page at 300*225 pixels, and they would like to go into it half of a file which is a lot longer than this. How can I trim this picture so that I can fit it into the required size? I have tried using the cut tool, but nothing seems to happen (I can draw a line, but can’t then do anything with it!
    Many thanks for any help…
    Jo
    Jofo replied 21 years, 5 months ago 2 Members · 4 Replies
  • Kim Mackenzie
    April 19, 2005 at 3:50 pm
    Draw a box or shape on top of your pic, where you want it cropped.
    Select both the shape and the picture.
    Go to menu Object > Clipping Mask > Create
    You can adjust the mask path by using the direct selection tool (white arrow) to drag the points around.
  • Jofo
    April 19, 2005 at 4:09 pm
    Ok – so I’ve done that – now how do I get rid of the rest of the picture that I have created the mask over? (It is still there, just hidden) I need to export this picture as a bmp, and every time I do, the bmp is too small because I have this extra bit sticking out!
  • Kim Mackenzie
    April 19, 2005 at 4:16 pm
    You need Photoshop or some other image editor to actually change the photo. Illustator can only clip/mask it.
  • Jofo
    April 19, 2005 at 4:40 pm
    Cheers – looks like I’ll be getting the ol’ Paint set out tomorrow, then!
