Activity › Forums › Adobe Illustrator › Illustrator Halftone Tutorial request
  • Illustrator Halftone Tutorial request
    Posted by Shali Shim on October 4, 2018 at 12:15 pm
    Hi there !
    I’m looking for a tutorial to creat a halftone pattern with complex shapes.
    Something that play with the thickness of the lines and where custom shapes can fit to a grid (or can be placed precisely)
    I’ve attached an example of what I’m looking for:
    Help will be much appreciated.
    Many thanks!
    Kalleheikki Kannisto replied 7 years, 12 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    October 5, 2018 at 3:01 pm
    Some general guidelines.
    1) Create the object at its largest and smallest size at the far ends of the gradient and use blend for the in-between objects
    2) Duplicate the blended object set by alt-dragging (option-dragging on mac) and ctrl-D (cmd-D) for duplicate transformation for additional copies. Hold shift to keep them aligned to 0/45/90 degrees.
    3) Expand the blends to access individual objects to delete them etc.
    Senior Graphic Designer
