Activity › Forums › Adobe Premiere Pro › Illustrator graphic artifact to premiere CS3
  • Illustrator graphic artifact to premiere CS3
    Posted by Trey Selman on December 20, 2007 at 4:59 pm
    When placing a illustrator graphic into the premiere timeline I get an artifact line that runs across the top of the graphic.
    I have tired multiple Ai graphics and Ai text and each one puts this pixel artifact across the top of the graphic in the time line.
    CS3 production suite is used.
    I even tired making a graphic in CS2 and it did the same thing when added to the timeline.
    I have tired adjusting the AICB settings and also the save as settings and all options have resulted in the same problem.
    Thanks for your thoughts.
    Trey Selman
    Trey Selman replied 18 years, 9 months ago 2 Members · 2 Replies
  • Jon Barrie
    December 21, 2007 at 2:48 am
    Are you certain you are using the High Quality setting in the Monitor and set it to 100% or accurate ideas of edges showing. Don’t select the layer either. It’s probably just showing as part of the non pixel for pixel (not 100%, but fit or another size).
    – Jon 🙂
  • Trey Selman
    December 21, 2007 at 5:16 am
    HQ is set and it shows at all magnifications including 100%.
    It show in preview but is also renders out and that is the real problem.
