Activity Forums Adobe Illustrator Illustrator graphic artifact to premiere CS3
  • Illustrator graphic artifact to premiere CS3
    Posted by Trey Selman on December 20, 2007 at 4:57 pm
    When placing a illustrator graphic into the premiere timeline I get an artifact line that runs across the top of the graphic.
    I have tired multiple Ai graphics and Ai text and each one puts this pixel artifact across the top of the graphic in the time line.
    CS3 production suite is used.
    I even tired making a graphic in CS2 and it did the same thing when added to the timeline.
    I have tired adjusting the AICB settings and also the save as settings and all options have resulted in the same problem.
    Thanks for your thoughts.
    Trey Selman
    Mike Gondek replied 18 years, 8 months ago 2 Members · 3 Replies
  • Mike Gondek
    December 21, 2007 at 12:49 am
    Are you sure that there is nothing there? Do an unlock all and check to see if a layer is locked. Theehn do a select all to see if anything in that area gets selected.
    A stray point might casue this.
    As a test export this to a bitmapped format and open in photoshop.
  • Trey Selman
    December 21, 2007 at 5:02 am
    Nothing selected
    It is happening on every single Ai file.
    I made new files with completly different object in the file and it occurs with these also.
    I even mad a new premiere project and it occurred in this project with new and old graphics.
    I am updated on all CS3 programs.
    Very peculiar?
    I also exported the Ai files to a psd file and brought those in and there is no problem with those.
    I could do this but it limits me from using ai files which should be possible.
    Thanks for your help. Any other ideas would be appreciated.
    Trey SElman
  • Mike Gondek
    December 21, 2007 at 3:50 pm
    try drawing a rectangle slightly larger than your object and choose object >> crop area.
