Illustrator files
Posted by David Gilhooly on January 19, 2006 at 5:58 pmI am using Zaxwerks proanimator 3. What version of illustartor can i use to do this. Can i use CS2 or do i need an older version?
John Dickinson replied 20 years, 7 months ago 3 Members · 9 Replies -
John Dickinson
January 19, 2006 at 7:42 pm -
Jon Okerstrom
January 20, 2006 at 1:21 amHi David,
If you run into issues, try saving your CS2 files with the compression option off. Whether you choose PDF compatibility shouldn’t matter.
Jon
David Gilhooly
January 20, 2006 at 10:02 amReason why i ask, is that when i attempt to bring an AI file in to Animator pro it tells me i don’t have enough memory.
Thanks Jon for responding. I heard your interview on the Cow podcast i thought it was the most interesting cast since the start.
All the best
David
John Dickinson
January 20, 2006 at 10:14 amThanks David, glad you liked the interview. Maybe you could email me the AI file and I’ll test it in my system, then we can narrow the problem down.
best,
John Dickinson
Motionworks
http://www.motionworks.com.au -
John Dickinson
January 20, 2006 at 8:39 pmOkay, your problem is that the file you are trying to use is not prepared correctly. I guess you either received it like this or imported this layer from Photoshop. Either way, you need to “recreate” this logo in Illustrator so that it is in “vector” form (made of paths). Maybe your client can provide an EPS file for you to use…
JD
John Dickinson
Motionworks
David Gilhooly
January 21, 2006 at 1:12 pmHi Jon
Well i have constructed a shape using paths in illustrator and then import it in to animator but still i get the same “not enough memory” thing. Maybe i am just not able to do this thing.
All the best
David
Jon Okerstrom
January 21, 2006 at 1:50 pmHi David,
Tell us about your system and version of ProAnimator to help us track down potential reasons for memory errors.
As John Dickinson (the other John) said, the files you’re making should be Illustrator format, with shapes and paths…. bit-mapped graphics will not work.
One more question for you. Can you open any of the objects or project files that came with the software without getting memory errors?
Jon
David Gilhooly
January 21, 2006 at 9:53 pmHi Guys
thanks for helping me. I am using Pro animator 3.0 and illustrator cs2 with a del 3.4Gb pc with 1Gb ram and windows xp pro.
david G
John Dickinson
January 28, 2006 at 12:20 amDavid did you end up solving this problem?
JD
John Dickinson
Motionworks
