Activity Forums Adobe After Effects Illustrator files not appearing in AE
  • Illustrator files not appearing in AE
    Posted by Greg Bager on April 25, 2006 at 5:11 pm
    I had this problem before and can’t recall the fix; I have two layers in illustrator of outlined text.
    when I import into AE 6.0 the file imports but the graphics are missing completely and only 1 of 2 layers appears. again, none of the illustrator text is visible when I bring to the comp.
    anybody know what I’m not turning on??
    Greg Bager replied 20 years, 5 months ago 4 Members · 5 Replies
  • Aris Blevins
    April 25, 2006 at 5:13 pm
    Are you getting the Invalid error? I’ve had issues with Illustrator files coming in as dots, and found that reinstalling After Effects solves it.
    Aris
  • Greg Bager
    April 25, 2006 at 5:18 pm
    no it imports just fine, goes through the motions and when the file imports there is nothing in the preview window nor when I drag it down to the timeline.
    totally frustrated…
  • Erik Pontius
    April 25, 2006 at 8:30 pm
    Might try making sure checking the box for “PDF compatible file” when you save the AI file.
  • Sean Corcoran
    April 25, 2006 at 8:31 pm
    What version of Illustrator are you using, and what format are you saving your Illustrator files in? Are your files RGB or CMYK?
  • Greg Bager
    April 25, 2006 at 8:52 pm
    Thanks Player that did the trick!
