Activity Forums Maxon Cinema 4D illustrator files in texture channels
  • illustrator files in texture channels
    Posted by Roy Mckenzie on September 1, 2010 at 3:55 pm
    I would like to know if anyone has used illustrator files as texture maps.
    I found this posting here at CC:
    https://forums.creativecow.net/thread/19/865673#865717
    Specifically I am interested in using a illustrator file as a texture and I am wondering if you can enable it to continuously re-rasterize, similar to the way after effects treats illustrator files.
    Is there a way to keep it full resolution(re-rasterized) as it moves extremely close to the camera? Additionally has anyone been able to enable an alpha channel for the imported texture?
    I am aware of importing illustrators as paths, I would like to import as a texture as not to redesign the illustrator file in C4D if possible.
    Thank you
    Roy
    Brian Jones replied 16 years ago 3 Members · 2 Replies
  • Adam Trachtenberg
    September 1, 2010 at 5:28 pm
    Illustrator files can’t be used as textures in Cinema.
  • Brian Jones
    September 1, 2010 at 9:13 pm
    [Roy McKenzie] “Is there a way to keep it full resolution(re-rasterized) as it moves extremely close to the camera?”
    only by rasterizing it out of Illustrator at a resolution high enough to be acceptable in your close shots.
