Activity › Forums › Maxon Cinema 4D › Illustrator files in texture Channel
  • Illustrator files in texture Channel
    Posted by Svenja Frahm on May 12, 2009 at 1:48 pm
    I’ve come across this annoying problem quite a few times already since using Cinema R11 and I cannot find ANYTHING about this… must be a bug though.
    In R10 I could easily load an illustrator file into a texture channel, but when I do this in R11 the texture turns completely black.
    Did this happen to anyone else yet? Any suggestions?
    Svenja
    Svenja Frahm replied 17 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • Adam Trachtenberg
    May 12, 2009 at 6:23 pm
    AFAIK Cinema has never supported the use .ai files in materials.
  • Brian Jones
    May 13, 2009 at 12:07 am
    maybe you are thinking about loading in an .ai file and using the imported spline in the Spline Shader?
  • Svenja Frahm
    May 13, 2009 at 8:33 am
    no, i am not… i just tried it again in R10 and it works fine.
    I create a new material and load my illustrator file (cs4) into one of my texture channels and it works.
    But I tried it in version 9 yesterday and it didnt seem to work in there as well… or cs4 ist just too new for release 9 to work… will test it again with an ai file saved in a lower version tomorrow.
    But still – it used to work in R10 and now its gone…
  • Adam Trachtenberg
    May 13, 2009 at 2:37 pm
    Does it render correctly in r10, or do you just see it in the viewport? It would be very peculiar if it works, as Cinema doesn’t support *.ai files in textures generally, and it doesn’t support any *.ai files above version 8 — at least officially!
  • Svenja Frahm
    May 13, 2009 at 3:07 pm
    here a screenshot of my test in R10:
    it is an illustrator cs4 file and renders fine!
    Here the same thing in R11:
    I agree that when importing ai files as splines, i would have to save them in version 8 in order to work…
    Anyway, that’s not the point… i cannot load any ai (or other vector format) file into a texture Channel in R11.
    Just for fun i’ve just tried to use an ai version 8 file in R10 and i get the same result like in R11 with any ai file…. black texture.
    so maybe it was a lucky coincident that cs4 files worked in R10?!
  • Adam Trachtenberg
    May 13, 2009 at 4:17 pm
    Very weird. I would report it to Maxon tech support and see what they say.
  • Brian Jones
    May 13, 2009 at 5:39 pm
    maybe it’s using the preview image embedded in the file?
  • Svenja Frahm
    May 13, 2009 at 9:18 pm
    probably… but why does R11 not do it the same way?
    mmmh might drop maxon an email then..
