Activity › Forums › Apple Motion › Illustrator files in Motion
  • Illustrator files in Motion
    Posted by Victor Goretsky on May 17, 2006 at 1:13 pm
    Is there any way in Motion to set (like in AE) “constant rasterizing” for illustrator files? I am resizing some files in Motion and illustrator graphics edges getting all gagged and blur. In AE I would hit “sun” shaped button and it fixes the problem. I couldn’t find anything comparable in Motion.
    And another oddity. If you apply “spin” behavior to the big illustrator file the WHOLE composition will jitter horizontally. The only workaround is to get the illustrator manipulation in AE.
    Bummer. I just took a three-day class in Motion and thought I could build the simple 10 sec commercial in Motion alone. It seems like a very cool app for small projects. Got a number of limitations or it just me.
    Victor Goretsky replied 20 years, 4 months ago 2 Members · 2 Replies
  • Slk3rd
    May 17, 2006 at 8:45 pm
    Lapotnik
    You should save the Illustrator File as a PDF. . . Import it into Motion, Highlight the MEDIA tab in your project window. Highlight the pdf file, go over to the MEDIA tab of the Inspector and UNCHECK the fixed resolution box. That should get rid of your jagged edges.
    try that.
    slk3rd
  • Victor Goretsky
    May 18, 2006 at 3:39 pm
    Thanks a lot. It worked like a charm. Edges are crisp now. Appears there is no need to resave illustrator files as PDFs. When I’ve looked at the media list in my project all illustrator files have been named or converted to PDFs on the Motion export, so all I needed was to uncheck “fixed resolution” box.
