Activity Forums Apple Motion illustrator files are cropped
  • illustrator files are cropped
    Posted by Lunarsimian on August 7, 2007 at 1:05 pm
    Hi – I am importing adobe illustrator cs3 files into motion 2.1. When i add a blur filter to the image, the blur doesn’t seem to extend past an ‘imaginary’ cropped area. It’s as though the file has been cropped tightly to the illustrator artwork. i can’t find any way to control this through Ai or Motion.
    Any ideas?
    Michael C replied 19 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Peter Wiggins
    August 7, 2007 at 1:44 pm
    Try applying the blur to the group, not the object.
    Peter
  • Lunarsimian
    August 7, 2007 at 2:40 pm
    Hi – no this doesn’t work either. Also, when I try to add a distortion filter to the imported file, it only shows the filter within the cropped area… I may have to work around it using alpha channels in photoshop.
  • Jeremy Garchow
    August 7, 2007 at 2:53 pm
    Did you change the crop area in AI?
    Jeremy
  • Lunarsimian
    August 7, 2007 at 3:04 pm
    I have tried that also – it doesn’t seem to make any difference. I’ve opened the ai file in photoshop at 720px x 576px with a transparent background and this works OK. I’m new to motion and final cut – this might be a glitch of some sort… cheers for the advice.
  • Jeremy Garchow
    August 7, 2007 at 8:58 pm
    Are you sure you changed the crop area and not the ‘stage’ area in AI?
  • Steve Cardwell
    August 7, 2007 at 9:40 pm
    If you look at the blur paramaters in the filters tab there is an option to crop with a tick box next to it, make sure this is unchecked.
    Hope this helps.
  • Michael C
    August 9, 2007 at 1:21 am
    Make sure that the element you are trying to blur has fixed resolution turned off. There is a good text file on this on http://www.motionsmarts.com
