Activity Forums Adobe After Effects Illustrator file change colour
  • Illustrator file change colour
    Posted by Lincoln Waldron on November 5, 2007 at 11:33 pm
    Being new to after affects i have an Illustrator file of a snow flake which is red, i want to change it white in after affects.
    Is there an easy way to change the colour in after affect?
    Marieke Hannen replied 8 years, 5 months ago 3 Members · 2 Replies
  • Darby Edelen
    November 5, 2007 at 11:53 pm
    If you want to change the color of the entire snowflake you can try using the Generate > Fill effect. Alternatively, if you have Illustrator you can change the color there, which would give you more options in terms of style/strokes/fills.
    You could also use Layer Styles if you’re working with AE CS3.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Marieke Hannen
    March 26, 2018 at 5:49 pm
    Still helpful more than 10 years later 🙂
