Activity › Forums › Adobe Illustrator › Illustrator Error
Illustrator Error
Posted by Janne Rissanen on April 13, 2015 at 1:38 amI can’t even create a new file.
Window popup says:
“The file “Web.ai” is an unknown format and cannot be opened”.
What’s the cause?
Eilis Hershon replied 11 years, 5 months ago 3 Members · 2 Replies -
Jonathan Ziegler
April 13, 2015 at 12:56 pmDo you see this as soon as you open illustrator? Does it crash the app? What version of ai? PC/Mac? What have you tried already? Usual suspects: trash the prefs, reinstall, delete and reinstall, close all other apps… Etc.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293 -
Eilis Hershon
April 15, 2015 at 4:54 pm1. Requires Acrobat (not just the Reader).
Works on (and was tested in) Illustrator version 10 and all CS versions.
>Open the corrupt file in Acrobat.
>Take the arrow tool.
>Click on any element or text in the document.
>Just move the object by hitting one of the directional arrows on your keyboard.
>File, Save.
>Open the file in Illustrator.
>It will say ‘this file has been modified outside of Illustrator’ or something to that effect. It will ask if you want to keep changes.
>Say ‘Yes’ (or OK)2. Apply third party tool if this method on above didn’t assist you Recovery Toolbox for Illustrator https://illustrator.recoverytoolbox.com/
