Activity › Forums › Adobe Illustrator › Illustrator Drop Shadow
  • Illustrator Drop Shadow
    Posted by Kiernan Sanders on June 29, 2008 at 7:32 pm
    I am running Adobe Illustrator CS on Windows XP on an older Dell laptop. When I attempt to give an object in my Illustrator artboard a drop shadow, whether I use the Filter or Effect menu, I am unable to change the blur setting, resulting in shadows that have no blur. I have used Illustrator CS on this laptop before, with the Windows 2000 OS, and had no trouble there. Can someone help me figure out why I am not allowed to change the blur settings for drop shadows? Thanks!
    Lisa Hughes replied 17 years, 10 months ago 3 Members · 4 Replies
  • Jeff Kelley
    June 30, 2008 at 3:10 pm
    I’m on a Mac but using CS. Under Effects/stylize you should see Drop shadow. The set the blur near the bottom on the box.
    Jeff
    http://www.willinois.com
  • Kiernan Sanders
    June 30, 2008 at 9:52 pm
    No, sorry, I should have been more clear in my question. My bad. But, what I meant to say is that the blur setting is there, but is all “blanked out.” It’s unavailable for selection, so I can’t enter a value or drag the slider. It’s like the computer or the program has decided to not make it an option.
    blur setting
  • Jeff Kelley
    July 1, 2008 at 6:19 pm
    I see.
    I wish I could help. I’ve tried everything I can think of to replicate the problem but have not been able to figure out why that would happen.
    Sorry
    Jeff
  • Lisa Hughes
    November 25, 2008 at 8:02 pm
    I am having the same problem, did you figure it out yet???
